Computer ppl: My PC is freezing up like crazy lately
lots and lots of fail
I'm running a Sony Vaio VGC-RA710G with a 3.2GHz processor, 512MB RAM, 250 gig HD running Windows XP Media Center 2005. Every time I have several programs running...like maybe Media Center TV, downloading a movie, surfing the web, etc, my PC will randomly freeze up. No errors, just frozen. The CPU useage rarely goes above 50%...I'm not quite sure what the deal is. I do virus/spyware scans will several scanners weekly, Defrags frequently, etc. Do I need more RAM?
Awhile ago my friend partiotioned my HD so that I have all of my system files on one side and all of my personal files on another. Could this be the problem?
Originally Posted by 98CoupeV6
Is there any way to test that out? I wish it was a car
h:
h:Download that zip and burn the image file, it will create a bootable cd. Then run memtest to test your memory.
In addition, you can try installing your ram into another machine and use it for a while to see if you can get it to lock up.
Before going and buying any hardware, first thing I would do is back up all your important files. Then do a clean install of windows, if the problem persists; then I would suspect a hardware problem ie: bad ram or failing hard drive.
90% of the time shit is fixed by an annual/semi-annual clean installation of windows.
Oh yeah, see if there are any bios/software updates for your motherboard by going to sony's website.
good luck.
more ram only fixes slowness ... it won't repair the random restart issue.
This really sounds like a driver conflict issue. When your PC restarts, note the programs that you were running. Try to reinstall those programs only. That might clean things up.
possible issues:
bad ram : download memtest... burn it to a disc, and boot to it.... it will scan your ram
overheating : open up the side of the case, and have a desk fan blow at it... see if it crashes.
progeam issue : does it happen in safe mode?
