Is this a bad thing? I think it is...
Old Mar 8, 2006 | 08:19 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Default Is this a bad thing? I think it is...
So, I was having some misfire issues this week after I put a new set of spark plugs in this weekend, so I took them out to regap them and look what I found:
The conductor has two fractures running all the way through it. What caused this on a new plug?
File Type: jpg
File Type: jpg
Old Mar 8, 2006 | 08:28 PM
rugsr's Avatar
rugsr
How do my taillights look
these cold plugs?
just one or all four?
Old Mar 8, 2006 | 08:29 PM
Provocateur
On permanent hiatus
Just cylinder 1. They are BKR7ES-11 plugs. One heat range colder copper plugs.
Old Mar 8, 2006 | 08:40 PM
1turbodc2's Avatar
1turbodc2
got boost?
wow taht is some bull shit!
Old Mar 8, 2006 | 08:42 PM
Exadar's Avatar
Exadar
Be Quiet and Drive
damn man, no good... refund on said spark plug maybe?
Old Mar 8, 2006 | 08:43 PM
dubcac's Avatar
dubcac
I
Heat maybe? :dunno:
Put in a new one and see what happens.
Old Mar 8, 2006 | 08:47 PM
Provocateur
On permanent hiatus
It is a $2 spark plug, I am over it. I just can't figure out if it was manufacturing error or my error. I guess time will tell.
Originally Posted by dubcac
Heat maybe? :dunno:
That is what I am thinking. My AFR's have gone berserk this week for some odd reason and I can't figure it out, so I assume I was running a little lean and the heat caused it to crack. I'll check them after I dyno on Saturday and see if it happens again.
Old Mar 8, 2006 | 08:54 PM
rugsr's Avatar
rugsr
Id put another one in and see if it does it again. How long were they in there for? If it does it again it may be cylinder 1's wire that could be causing it
Old Mar 8, 2006 | 09:07 PM
Provocateur
On permanent hiatus
They were in since Sunday. If it happens again, I will be very concerned. I have an extra set of wires too, so that would be the first thing I would do after it is retuned.
Old Mar 9, 2006 | 11:51 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
If there is something wrong with your car that your cannot quite figure out internally it is going be taken out on the plugs when the cylinders fire. Was the car backfiring along with the misfire or just a misfire? Did you get on the car while it was still cold? You can crack a head doing that, maybe a spark plug too? I don't know...
