LS/Vtec in a '95 Civic
Old Mar 8, 2006 | 07:19 PM
nangwalt's Avatar
nangwalt
Default LS/Vtec in a '95 Civic
Here's the deal I have a '97 or '98 b18b all stock block with a '00 Civic Si b16 Vtec all stock head and an LS tranny. Already installed is a DC Sports Header, Datum 1 fuel pressure regulator, Mugen P28 racing ECU, Skunk 2 adjustable cam gears, AEM cold air intake, BOMZ underdrive pulley, NGK plugs-wires-cap-rotor, and BOMZ test pipe. My question is if this was your setup what would you do next? Not considering a turbo upgrade. This is my first venture into the Honda tuning scene and any help would be great. Thanks
Old Mar 8, 2006 | 08:26 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
If it hasn't been properly reinforced to take an 8k rpm redline, I would do that first. After that, I would think about cams.
Old Mar 9, 2006 | 08:36 AM
nangwalt's Avatar
nangwalt
Default Rpm?
With the setup as it is what is a safe redline?
Old Mar 9, 2006 | 09:34 AM
raiden571's Avatar
raiden571
turning u inside out
whatever is stock redline for a non vtec motor. i would put arp rod bolts, and head studs in it and then id say it could handle the b16 redline
Old Mar 10, 2006 | 07:57 PM
nangwalt's Avatar
nangwalt
Old Mar 10, 2006 | 09:10 PM
95LSv's Avatar
95LSv
Banded
Where can I get some GSR ARP rod bolts? And how much do you think they are? Also where can I get some intake and exhause head studs?
Old Mar 11, 2006 | 06:38 AM
raiden571's Avatar
raiden571
http://tunertoys.zoovy.com/category/arp_hardware/
