View Poll Results: what do you think i should do
fix it myself....it is of course my responsibility
13
92.86%
take it to some creep to be ripped off
7.14%
Voters: 14. You may not vote on this poll
hottie in distress!!
Old Mar 8, 2006 | 01:40 PM
AcuraGirrl23's Avatar
AcuraGirrl23
Default hottie in distress!!
hello..well the problem started about last month..and i thought was nothing major at first untill it started to missfire..i lost alot of power..and i was ideling at about 15oo to 17oo rpm...i had it checked and they said it was the distributor ..well i bought the parts but now they want to charge me my first born to put it on there...and well i figured...this is my baby..i wanted to do it myself...so guys what im asking is..if anyone of you knows how to change a distributor out on a 91 integra LS..i would be totally greatfull...please e-mail me or post or something..im gonna try to figure this crap out tonight...so guys...help a girl out... thanks!!
AcuraGirrl23
panama city florida
Old Mar 8, 2006 | 01:45 PM
Driverman5777's Avatar
Driverman5777
get a Haynes or Helms manual. It tells how to do all.
Old Mar 8, 2006 | 02:34 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Pic doesn't work. Need pic first.
Are you sure the distributor is the problem? When was a tuneup of the basics last done?
Old Mar 8, 2006 | 03:42 PM
dubcac's Avatar
dubcac
I
If you want to change the distributor, you're going to need a timing light to accurately set the timing. The actual distributor change is easy...3 12mm bolts and a harness clip.
Old Mar 9, 2006 | 03:54 AM
k-series's Avatar
k-series
AcuraGirrl23
panama city florida
If you were closer, I could do it for you. I just changed the dizzy in my 92 RS. 3 bolts, line up the dizzy, bolt it in, done.
Steve
Old Mar 9, 2006 | 08:47 AM
dubcac's Avatar
dubcac
I
I hope you used a timing light.
Old Mar 9, 2006 | 08:56 AM
mr.crx's Avatar
mr.crx
you dont need a timing light. you are not moving it that much so you can just try to get as close as you can. i just did a few weeks ago and had no problems and have done it before. you mark what cables go to which on the distributer, so when you put it back together you dont put cylinder 1 into cylinder 4 and what not. then you take off three bolts slap the new one on there and bolt it back up if you can find a way to match up where the last one was sitting then your in great shape. then you hook up all the cables and your done. simple fix. and i have done that several times and not messed up the timing.
Old Mar 9, 2006 | 09:02 AM
dubcac's Avatar
dubcac
I
Not moving it that much? It's a complete distributor replacement. Do you know how much movement it takes to change the timing a lot? Not very much.
Old Mar 9, 2006 | 09:03 AM
Yea when we changed the distributor on my civic i didnt need a timing light :dunno:
But then again that car doesnt run either :hsugh:
Old Mar 9, 2006 | 09:05 AM
k-series's Avatar
k-series
Nope, sure didn't.
Steve
