GSR bare Block Need help asap
Old Mar 4, 2006 | 06:40 PM
95LSv's Avatar
95LSv
Banded
Default GSR bare Block Need help asap
This guy is selling a 95 GSR bare block and a crank and rods, all with around 9x,xxx miles on them. Hes asking $200. Is this a good price, because i would like a gsr block...???
Old Mar 4, 2006 | 07:18 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Sounds like a good deal to me.
Old Mar 4, 2006 | 09:27 PM
95LSv's Avatar
95LSv
Banded
What is the STANDARD sleeve size on a b18 block? This guy has them at 84mm, is that standard or oversize??
Old Mar 4, 2006 | 10:01 PM
Provocateur
On permanent hiatus
That is not a standard size. The standard size is 81mm, so that is a 2.0L if you use the GSR crank. Unless it is sleeved, I would stay away from it, though. Stock sleeves bored that much will crack.
Old Mar 4, 2006 | 11:27 PM
95LSv's Avatar
95LSv
Banded
Thanx Schmoo, you've been very helpful . Oh and can you tell me if ACL rod/ main bearings are good? This guy is selling a whole set main, rod and including thrustwashers for $75.
Old Mar 5, 2006 | 12:01 AM
Provocateur
On permanent hiatus
Yes, they are good. A lot of builders use those. Either use those or OEM for the best results.
Also make sure you plastiguage the clearances.
Old Mar 5, 2006 | 12:10 AM
95LSv's Avatar
95LSv
Banded
Yea ive just read about that today on Cspeedracing. But what do I do if there isn't enough clearance??
Old Mar 5, 2006 | 12:51 AM
Provocateur
On permanent hiatus
You get a smaller bearing. I don't know how the ACL bearings work since all clearances are usually different.
Old Mar 5, 2006 | 12:58 AM
95LSv's Avatar
95LSv
Banded
Crap, thats gonna suck since i just bought the ACL's. Can i just shave the bearing?
And you know when you do a valve adjustment, does the head need to be on the block, because myne isn't and it seems it would be a whole lot easier to do it now before i put the LS-vtec together.
Old Mar 5, 2006 | 11:44 AM
Provocateur
On permanent hiatus
No, you can't shave the bearings...unless you want to spin one as soon as the car is started.
Yes, you can do a valve adjustment with the head not on the car. Just make sure the cams are bolted in securely and you know which cylinder you are adjusting.
