low oil pressure light
Old Mar 2, 2006 | 10:59 AM
koter18's Avatar
koter18
Default low oil pressure light
i was one ma way home n the oil pressure light kept flashing on the gauge but i ignored it il i got home which was about a half an hour. when i got home i check the oil level it was fine. what could it be??? i restarted the car it wasn't flashing...weird
Old Mar 2, 2006 | 02:59 PM
tRyFfLiN's Avatar
tRyFfLiN
Ci\/iCs Suk
damn, im sayin, my shyt does that too, anyone know why?
Old Mar 2, 2006 | 05:38 PM
mrproul's Avatar
mrproul
oil pick up at the bottom of the crank could be cloged.
Old Mar 4, 2006 | 11:54 PM
IntegraGSR12's Avatar
IntegraGSR12
Also you could try changing your oil pressure sending unit located beside the oil filter the wire could be a little loose if so that would trigger the light if it is just barely snaped on it could trigger when you hit bumps or accelerate??
Old Mar 5, 2006 | 01:10 PM
carta79's Avatar
carta79
Life after death
Check the oil pressure, simple as that. If the oil pressure is within spec, replace the engine oil pressure switch and recheck. If it's not within spec, inspect the oil pump.
10 psi minimum at idle
50 psi minimum at 3,000 rpm
Were you driving the car pretty hard that day. I can get the oil light to come on by taking a corner to fast.
Old Mar 6, 2006 | 01:30 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
A common mis conception is that the oil light comes on when you are low on oil. Maybe on some cars but not all. I would have it tested, caus obviosly something caused it to come on. Maybe a blurp, but who knows...
Old Mar 15, 2006 | 08:12 PM
nemesis2's Avatar
nemesis2
Might wanna have your oil pump checked out, typically it's located in the oil pan opposite the pan base.
Old Jul 10, 2006 | 03:21 PM
angel666's Avatar
angel666
Default I have the same problem too, but.....
My oil pressure light starts blinking at highway speeds. Once I switch off the engine and on and drive local roads the doesnt blink. Anyone thinks its because of a loose oil pressure sending unit?
Old Jul 10, 2006 | 03:33 PM
carta79's Avatar
carta79
Life after death
Well I wouldn't be driving the car if a flashing oil light comes on. You could possibly damage the engine. I said it before and I'll say it again, get your oil pressure checked.
Old Jul 10, 2006 | 03:53 PM
angel666's Avatar
angel666
Thanks for the reply. But why does the light blink only at high speeds?
