strange squeak
Old Feb 28, 2006 | 09:14 AM
R_Squared's Avatar
R_Squared
LEVEL UP
Default strange squeak
For about the past week, I've been hearing a strange squeaking noise coming from the engine bay when the car is running. I don't think it's a loose belt but I'm not sure what else it could possibly be? I know this is a pretty vague description but I don't know what else to say about it. It's getting really annoying.
Old Feb 28, 2006 | 09:28 AM
dohcmonster's Avatar
dohcmonster
check your A/C belt, timing belt, P/S, etc...... its a belt
Old Feb 28, 2006 | 09:50 AM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
get a video/audio clip for us... have it idling... and then rev it to 3-4 and then back down... it would give us a better way to respond
Old Feb 28, 2006 | 03:19 PM
R_Squared's Avatar
R_Squared
LEVEL UP
i'll see what i can do about the a/v clip...but as for the noise in general, could possibly be an exhaust leak, like at the header or nearby? I donno, just a shot in the dark. From what I can tell, the noise isn't really constant. I hear it sometimes more than others, like especially when the idle dips too low.
Old Feb 28, 2006 | 03:42 PM
aboobybobpleez's Avatar
aboobybobpleez
Certified Rice-Rocket
maybe a loose mount?
Old Feb 28, 2006 | 03:44 PM
dubcac's Avatar
dubcac
I
An exhaust leak wouldn't squeak. Check all your accessory belts....alt/ps/ac.
Old Feb 28, 2006 | 04:47 PM
mxl36o's Avatar
mxl36o
1999 Accord 4 cyl
i had this sqeak, which sounds like a pulley spinning. It goes away when i step on the clutch though.
Old Feb 28, 2006 | 05:55 PM
R_Squared's Avatar
R_Squared
LEVEL UP
aaaaaand theeeeen? I mean, what did you do to get rid of the squeak...you said you "had" it...past tense.
Old Mar 1, 2006 | 04:14 PM
exbrick's Avatar
exbrick
I'd rather be driving.
I found this thread while searching for answers to my own sqeak. Mine sounds like a cricket chirping but very fast...specifically whatever speed the engine is going. I've had my head under the hood a couple of times and pinned it down to the general area of the drive belts. One of said belts feels rubbery and generally good, the other feels hard and rough like sandpaper. I have to believe that it's the hardened belt, and there's probably a particularly bad patch somewhere on its length that causes the rhythm. It's that or bearings being tosted somewhere, but either way that belt is going away this weekend.
Old Mar 3, 2006 | 04:57 PM
R_Squared's Avatar
R_Squared
LEVEL UP
I think I've narrowed my problem down. I'm pretty sure my squeak is actually from my exhaust manifold. I think somewhere along the header there is a gap, possibly between the header and A pipe, which is causing the exhaust to rattle and squeak. Any ideas on how to fix this?
