Seafoam...
Old Feb 27, 2006 | 12:46 PM
R_Squared's Avatar
R_Squared
LEVEL UP
Default Seafoam...
I keep hearing about this "Seafoam" stuff that you run through the engine and it supposedly yields pretty amazing results. I am interested in using some in my '94 teg but I was just wondering if someone could clearly explain how to use it. The last thing I want is to ruin my motor or anything else by putting the stuff in wrong.
Old Feb 28, 2006 | 06:02 AM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
I used it a while ago,it worked great. I believe that the can says you can pour it in your crank casing, im not sure of exactly how much, check on the can.
Old Feb 28, 2006 | 07:01 AM
rugsr's Avatar
rugsr
How do my taillights look
does it just clean the motor out? lke carbon build up?
Old Feb 28, 2006 | 07:36 AM
EH339's Avatar
EH339
I use Honda Top End Cleaner. My bf is the one that puts it in through. It's sort of unsettling to watch. Do a google search, I know that there have been many writeups on how to use these engine cleaners.
Old Feb 28, 2006 | 09:56 AM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
i've never trusted seafoam... but i've heard it working several times.. some guy on here put a full can in his gas tank and completely cleaned out his injectors... u can put some in ur intake to clean ur TB/IM... theres several good uses for it
Old Feb 28, 2006 | 01:34 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Here's the writeup from Sea-Foam.
http://www.seafoamsales.com/motorTuneUpTechGas.htm
I've always been wary of the PCV method.
Introducing any fluid into the intake manifold is a little too risky IMO. :noes:
I've used Berryman's C-12 Chemtool to great effect with all the cars I've owned. With the DC4, I add two-thirds of a can to the petrol tank just before a complete fill-up. Later, right before I change the oil, I follow their instructions for use a crankcase detergent. With C-12, it is imperative that you change the oil immediately after a crankcase treatment.
Old Feb 28, 2006 | 05:04 PM
used and sold seafoam for years now and will swear by it till the end!!! have ran it through the fuel tank and the crank case as well as used a vaccuum line to suck it directly into the intake....first time u do it this way its scary lookin but works so try it....
Old Feb 28, 2006 | 05:57 PM
R_Squared's Avatar
R_Squared
LEVEL UP
dumb question...but how do you add it to the integra's crankcase? just put it in where you add oil? Also, I'm still not sure how exactly you sucked it into the intake...
Old Feb 28, 2006 | 07:02 PM
rugsr's Avatar
rugsr
mabye where the breather goes?
Old Feb 28, 2006 | 07:06 PM
add it in just like u would oil...and as for the intake just use a vaccuum line off of the intake and stick it in the can....sucks it right up. kills the motor, let sit for like 15 minutes...then start the car and watch it smoke like a bitch
