Viper 791/771xv(alarm) Review
Hello everyone,
i just got the 791xv installed on my 97 integra and just wanted to do a review from the people that were considering buying it....
Pro:
-awesome alarm system... not super sensitive (exhaust will not set it off)... and i got it for 200shipped (http://www.pricegrabber.com/search_g...&search=791+xv)
-"turbo timer mode" allows car to cool down for set period of time
-passive lock and passive security systems are incredible
-passive lock = 30 seconds after the car is started w/ keys in ignition... the doors will automatically lock (similar to newer cars)
-passive arm = 30 seconds after all the doors are closed and car is shut off... car will automatically arm just in case you forget to set or you are busy
-programming and valet switch very easy to understand and makes programming additional things (passive/active arming/locking) very simple to do even if the installer did not program the style that you would prefer.
-a quick glance through the book will give you the options to program and alter several things about the alarm
-has a default alternator cutoff (30 seconds after car is armed... starter will not work, until disarmed/key in ignition
thats about all i can think of as far as PRO's ... there is plenty more... i just haven't figured it out yet...
CONS:
-annoying beep from remote (can be changed but i haven't figured out how to yet)
-very difficult to install... so even with extensive electrical knowledge... generally easier and less of a headache to let installer do for you
-because of the several features... one button or combination on the remote can enable/disable things that you did not plan to enable/disable... makes difficult to carry around in tight pocket/purse
so far it has done everything i want and more
any questions/comments/concerns post here or PM me ...
-ryan
Pro:
CONS:
-ryan
didn't personally install it... but i have before on other cars when working at BB... hardest or at least most annoying was the dome light relays and the window switches... it's all not too difficult but those both require lots of wires to be run in very small spaces
The range is kind of puny too, I noticed. I like mine overall, though.
If you want to disable the beeping, hold the P button on the back of the remote until it beeps once and then press the lock button. Then hold the P button down for two seconds, release and it should beep twice. Now it is silent.
that is a seperate setting... i like this one... by the time i start driving is usually when the car locks, and then since i use the turbo timer almost every time i park... it makes sure i leave it in nuetral... and when u set the timer for it ... the car unlocks... so all is well
