G28r Turbo, Do i need to change fuel system when installing a turbo system?
I found a Garret turbo kit i like, do i have to change the fuel syste, i.e., injectors and pump...if so what should i change them to?
Stock Garrett Turbo Kit HP 109whp @ 6600rpm 176whp @ 6850rpm Torque 95lbf· ft @ 5100rpm 140lbf· ft @ 5400rpm
1. Honda Civic
SOHC D16Y8
The Garrett Honda Civic kit is for the D16Y8 SOHC engine for model years 1996-2000. A GT28R ball bearing turbocharger and all of the necessary components are included to complete the installation in your garage!
1. Honda Civic
SOHC D16Y8
- Emissions certified in all 50 States
- Model years 1996-2000
- GT28R Turbo
- Garrett exclusive ball bearing turbo for unbeatable response, efficiency, and durability. Absence of a thrust bearing eliminates failures at elevated boost levels
- The most complete kit on the market
- Includes everything you need to install; Intake Manifold, Intercooler, TiAl Blow-off valve, Ni-Resist exhaust manifold, turbo-link piggyback ECU
- Was $3,778.95
great...now his next question is going to be...what should i run for fuel pump and injectors....and then my response will be....HOW MUCH BOOST YOU PLAN ON RUNNING. if he is only going to run about 5 (i even think up to 8 is ok) he really doesnt need to change anything....wouldnt the kit come with bigger injectors or fuel pump (i know kits rarely come with these items) if greddy thoguht this was nec? it is not...so the question remains...how much boost you planning on? sure ...in a perfect rich world...yes lets upgrade everything possible...but it is not needed
how much boost could i ask out of a d16y8?
would i have to strengthen any internal parts of the engine?
if so, is this engine worth it or should i swap it, and for what?
i really appreciate your help.
I was reading that all i should ask out of my stock engine is 6psi and to upgrade injectors to which ever fmu system im using. 720cc i think. i dunno.
is this engine worth it i mean, being auto n all?
i was lookn under my sis n laws hood she has a b18c i think im gonna steal it. think she'll notice?
