Lowering?
Old Jan 31, 2006 | 01:13 PM
Yogart's Avatar
Yogart
Default Lowering?
oke i got an 3dr hatch back 92-95 EG4 , at the moment it has got 40mm lowering springs but the ride is realy unconfontable i was thinking of changing the springs for an full suspension kit 40mm , will that make the ride better ?
if not then im gonna put the old springs back in.
Old Jan 31, 2006 | 01:22 PM
ReVenGe's Avatar
ReVenGe
welllllll.... it depends mostly on the brand..... not so much the drop.
Old Jan 31, 2006 | 01:31 PM
Yogart's Avatar
Yogart
oh right , but for comfort whats the best solution ? is it stock ? cause im realy thinking putting stock springs back in and just get 17's at the moment i have 15s
Old Jan 31, 2006 | 06:36 PM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
Stock would probably be the most comfortable and quietest ride but for comfort and performance a fully adjustable coilover set would probably be the best solution.
Old Feb 1, 2006 | 01:53 AM
Yogart's Avatar
Yogart
i spose coilover is the best option but not the cheepest , can someone tell me if this would be oke for comfort
http://www.europerformance.co.uk/pag...mhtml?id=39419
thnx
Old Feb 5, 2006 | 05:30 AM
twinring's Avatar
twinring
I installed a used set of JIC FLTA2's on my EG6. The ride was so harsh, esp. in the rear. I bought and installed a 98 spec ITR rear swaybar and an A-spec racing brace and the ride became quite pleasant with the added benefit of beter cornering.
Old Feb 5, 2006 | 06:17 AM
JDMtunedEK's Avatar
JDMtunedEK
you will always have to do a little more "adjustment" to your suspension when you decide to lower your car. especially if you lower it more than 1.5 inches. sway bars and other braces can help dramatically.
Old Feb 5, 2006 | 06:20 AM
twinring's Avatar
twinring
I agree
Old Feb 6, 2006 | 02:29 AM
Yogart's Avatar
Yogart
kool , so with some sports shock absorbers it would make a big difference?
Old Feb 6, 2006 | 02:57 AM
twinring's Avatar
twinring
it also depends on the tires you use, some compounds are harder than others.
