b16 from 00 si into 94 cx
Old Jan 26, 2006 | 07:55 PM
ReVenGe's Avatar
ReVenGe
Default b16 from 00 si into 94 cx
yes...... theres a bunch of swap how tos.......... but i just need to check the specifics before i take out my old engine and be get stuck cause i need some stupid plug or something to hook my new one......
now i have the whole shibang ----- engine tranny axles p28 ecu and harnes....... is there some problem im going to run into? like how hard is it to take out the old ecu and plug in the wires etc..... i dont even know if mines obd1 2 or 0..... so any help would be appreciated.
its a b16a2 and tranny from a 00 si with p28 ecu
and i gots me a 94 cx with the all powerful d15b8
Old Jan 27, 2006 | 03:29 AM
extensioncordy's Avatar
extensioncordy
EG6
your car is obd1 and the b16 is obd2
Old Jan 27, 2006 | 04:30 AM
waaBAAH's Avatar
waaBAAH
it will still work. i am missing things here so please correct me. you are going to need to switch things or rewire things. things include injectors....distrubutor....altenator. those have to be obd1 (for your car)
Old Jan 27, 2006 | 09:40 AM
ReVenGe's Avatar
ReVenGe
right... it comes with all that thankfully.... he basicaly pulled everything in one big glorious peace from the car and is throwing in a box over here..... but my concern i gues is the other things that are not a part of the engine that plug into the ecu...... like the dash and etc.... does that plug into it and will it fit?
Old Jan 27, 2006 | 09:49 AM
waaBAAH's Avatar
waaBAAH
so you have obd1 ecu, alt, injectors,dizzy? his engine is obd2. you need obd1 parts!!
Old Jan 27, 2006 | 11:08 AM
ReVenGe's Avatar
ReVenGe
yep...... comes with all the parts..... so im good there.... my main question is in stock things that dont have to do with the engine...... or is there nothing else that plugs into the ecu besides it?
Old Jan 27, 2006 | 03:57 PM
qtiger's Avatar
qtiger
You do not need to swap to OBD1 parts. All you need is the OBD2 engine harness. Plug it into your chassis harness and you are done.
Old Jan 27, 2006 | 04:03 PM
ReVenGe's Avatar
ReVenGe
good. i think i'l take lots of pictures and make a diy. anyone else have anything else for me to watch out for our check to make sure i have before i yank out my old engine and get stuck willl be appreciated.... otherwise...... awaaaaaaaay i go ;-D
Old Jan 28, 2006 | 01:11 AM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
you need a gsr harness. You also need ob1 dizzy, alt, injectors. Thats the way i look at it. If you get a gsr harness it will plug right in at the fire wall connections.
Old Jan 28, 2006 | 08:40 AM
waaBAAH's Avatar
waaBAAH
way to much work to run an obd2 harness. an obd 2 harness is a one pice design so you would need to run everything into the firewall. would be a lot easier just to get obd 1 parts......like you said you have....and just get a gsr harness. plug and play from that point. might need to longte a wire or two but for the most part...it is simple
