Help me out HAN
Old Jan 20, 2006 | 08:23 AM
2gr84u's Avatar
2gr84u
2gr84u
Default Help me out HAN
Alright, about 2 months ago my tranny and clutch took a shit on me. SO I bought a stage 3 6 puck clutch from LSD motorsports (great company, and alot of people on Homemadeturbo.com love the clutches) I also installed a 7lb fidanza flywheel. I used a JDM d15b tranny to replace my dead z6 tranny. Ever sence my brother has brought the car home sence he installed this stuff it hasnt worked right. First the clutch pressure doesnt seem to be what it should be. We figured it was due to a leaking master and slave cylinder, so both were replaced. This didnt help clutch pressure so we figured it needed a better means of bleeding. While my bro used his pnumatic bleeder (or however thats spelled) at the dealer and the clutch STILL doesnt feel as hard as it should. The next big issue is 3rd and 4th will grind if i shift in boost unless i push the clutch all the way in, wait a second, then shift. Also, its not doing it as much as it did, but the clutch is occasionaly slipping, which it shouldnt because its rated for 300fttq and im probably at 180tq at best.
SOOO whats the deal here guys? I need suggestions. Does this sound like it could be the wrong pressure plate? Its an idea that accured to me and my brother due to the stock like pedal pressure.
Old Jan 20, 2006 | 09:20 AM
97civicEXVTEC's Avatar
97civicEXVTEC
how long have you had the clutch installed? was it broken in properly? this is just a thought, but id look up what a flywheel that light will cause because i heard they have some negative effects. good luck.
Old Jan 20, 2006 | 10:11 AM
2gr84u's Avatar
2gr84u
2gr84u
the clutch had about 500+ miles of easy driving break in time. Ive never heard of a lightend flywheel causing drivetrain issues
Old Jan 20, 2006 | 11:07 AM
97civicEXVTEC
i didnt mean it by causing issues. driving a car with a flywheel that much lighter will change your driving experience. i dont know if that has anything to do with your problemm, i was just throwing it out there.
Old Jan 20, 2006 | 11:18 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
do you have another car with the same clutch or something? I guess Im trying to figure out how it doesnt "feel right" is it really loose or just not as hard as you were expecting?
Old Jan 20, 2006 | 01:00 PM
2gr84u's Avatar
2gr84u
2gr84u
The clutch feels stock, i know through others the clutch should feel considerbly stiffer over the stock clutch.
Old Jan 20, 2006 | 01:02 PM
Jafro's Avatar
Jafro
I'm made of meat!
Maybe the step-height is wrong on the flywheel. If it's off by .002" it's enough to make it drastically different on the pedal. But before suspecting that, I would check to make sure the slave cylinder isn't pre-loaded. If the clutch master cylinder is adjusted properly, it might not be letting all the pressure off the pressure plate, and your clutch won't fully release. Usually this won't be accompanied by grinding gears, but it can in rare cases.
Get that thing sorted out. I want to see you at Dyno Day.
Old Jan 20, 2006 | 01:08 PM
2gr84u's Avatar
2gr84u
2gr84u
hah im going most likly either way lol It holds well enough for me to get good runs in. Im thinking im gonna do a couple power runs at Promotion Tuning this week, there haveing a special for 50 bucks for 3 pulls, and its only an exit down the road from me heh
Old Jan 22, 2006 | 03:29 PM
Jafro's Avatar
Jafro
I'm made of meat!
Does it include A/F metering? Most shops charge extra for that. Extreme's got the sniffer. There's no additional charge or discount whether or not you use it. They always do anyway. :thumbup: Extreme uses an AWD DynoJet, too.
Old Jan 22, 2006 | 09:06 PM
2gr84u's Avatar
2gr84u
2gr84u
its an awd dynojet, but I dunno whether there charging for air fuel or not. Ive got a plx-m300 wideband though so its no biggy.
