Timing belt tension
Was just able to get my timing belt on after a day of agony. Just wanted to make sure it's tensioned properly before I button everything else back up. I employed the method where I put the no. 1 piston at TDC and had the cams pointing up. Following the manual I had, I turned the crank six times counter-clockwise and verified that I was back at TDC, and didn't bump any valves along the way. Then to tension the belt, I loosened the belt tensioning bolt a 1/2 turn the turned the crank counter-clockwise three teeth to tighten it. Then I torqued down the tensioning bolt. The belt is nice and tight across the top and front, but the back side (facing the driver) still has a bit of slack to it. Was wondering if this is normal, or did I mess it up and need to start over??
after turning the crank a few times and bringing it back to TDC, there's now a little play going across the top. How can I make it tighter? Can I crank more then three teeth past TDC during the tensioning step?
The tensioner only applies tension to the section of the timing belt where the tensioner is. When I did my timing belt I did have a little slack in the belt on that section of the belt. Just try and get the belt as tight as you can but keep in mind there will be a slight amound of slack. What year and model Integra do you have?
Thought I'd use this again rather than open a new thread....
Got everything back together... When the car was running the timing belt looked as it had a little too much slack. In addition to that, when out test driving it, the only time I revved it a bit, I noticed the tach jumping around. I figured I still didn't have the timing belt tight enough. So, I've tried to tension it again, but am still not sure if it's OK. This time I turned it just more than one turn past TDC. It seems to tension across the top, but not between the water pump and intake cam. Also, when I turn the crank, I get some resistance followed by it spinning freely. When it spins freely is when it seems to loosen up. Before I put the ps pump back in and the valve cover on, just want to see if there's anything else I can try...
btw, this is a '96 LS/VTEC with B18C5 head.
