95 integra distributor
Old Jan 1, 2006 | 03:29 PM
addan's Avatar
addan
Default 95 integra distributor
have a 95 integra, and the distributor got stolen, can I use one off a 97,
or are they different,
thanks alot for the input, integra its the special edition, the plugs from the distributor are square, not round, can I do any changes to make a different year distributor work
Old Jan 1, 2006 | 03:59 PM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
yes, as long as your trim is the same as the car your getting it off of... LS/GS/RS are all the same, GSR is diff.. and Type R is diff
Old Jan 1, 2006 | 04:34 PM
teg92's Avatar
teg92
WHAT OK YEAH!
NO you cant 95 is OBD1 and 97 is OBD2 the dizzy plugs are completly different
Old Jan 1, 2006 | 05:22 PM
VPUPPY's Avatar
VPUPPY
What trim is your Integra?
Old Jan 1, 2006 | 08:18 PM
aboobybobpleez's Avatar
aboobybobpleez
Certified Rice-Rocket
you can swap the plugs if you dont wana drop money on a new one
Old Jan 2, 2006 | 07:13 AM
VPUPPY's Avatar
VPUPPY
I believe its just more than swapping plugs. I believe there is a small difference in the actual wiring.
Old Jan 2, 2006 | 10:55 AM
teg92's Avatar
teg92
WHAT OK YEAH!
there is a difference just get an OBD1 dizzy, it will be alot easier and you wont have to mess with any wiring. IMO
Old Jan 2, 2006 | 02:34 PM
aboobybobpleez
the wires are the same...i have an obd1 engine/dizzy but i had to use and obd2 harness..i just swapped the plugs and soldered the wires together and it works perfect
Old Jan 2, 2006 | 02:59 PM
tegbooster's Avatar
tegbooster
i thought that a 95 was an OBD2?
Old Jan 2, 2006 | 03:04 PM
teg92's Avatar
teg92
WHAT OK YEAH!
92-95 OBD1 96 and up OBD2
