code reading
Old Dec 29, 2005 | 11:34 AM
montemann's Avatar
montemann
Default code reading
I checked the ecu blinks and it blinks 8 short blinks over and over
89 integra 1.6 5spd
does anyone know what that means
Thanks
Old Dec 29, 2005 | 03:37 PM
Brar's Avatar
Brar
teamintegra would help...but their site is down
o and it sounds like code 8
Old Dec 29, 2005 | 10:40 PM
tahafisaka6's Avatar
tahafisaka6
I believe the codes are similar if not the same for your year of car.
When the car is in the ON position, the check engine light emits two different flashes; a long extended flash means 10, and a rapid flash means 1. So, one long flash, another long flash, followed by 3 quick flash stands for...................23! Equipped with that information, here are the codes for the '92-'00 Honda and '94-'00 Acura.
0 ECU
1 Oxygen Content
3 Map Sensor
4 Crank Angle Sensor
5 Map Sensor
6 Coolent Temperature
7 Throttle Angle
8 TDC Position
9 No 1 Cylinder Position
10 Intake Air Temperature
12 Exhaust Gas Recirculation System
13 Atmosphere Pressure
14 Electronic Air Control
15 Ignition Output Signal
16 Fuel Injector
17 Vehicle Speed Sensor
20 Electronic Load Detector
21 VTEC Solenoid Valve (1.8L GSR)
22 VTEC Oil Pressure Switch (1.8L GSR)
23 Knock Sensor
30 TCM Signal A
31 TCM Signal B
41 O-2 Sensor Heater
43 Fuel Supply System
45 System Too Rich or Too Lean
48 Primary Heated O-2 Sensor
54 Crankshaft Speed Fluctuation Sensor
61 Primary O-2 Sensor Circuit
63 Secondary O-2 Sensor Circuit
67 Catalyst System
70 Automatic Transaxle
71-74 Random Misfire
80 Exhaust Gas Recirculation
86 Engine Coolant Temperature Circuit
90 Evaporative Emission Control System Leak Detected
91 Fuel Tank Pressure Circuit
92 Evaporative Emission Control System Insufficient
Old Dec 30, 2005 | 05:16 AM
montemann's Avatar
montemann
It says for code 8 TDC position. When I put the new distributor in, the ses light came on immediatley, and now that i think of it, there is a little bit of pinging or something. did i put the distributor on wrong? How do i correct the situation properly, I thought it only went in one way. do i have to twist it or something
Thanks
Old Dec 30, 2005 | 05:58 AM
montemann's Avatar
montemann
Default codes
I did some research and it says there is tdc sensor inside the distributor, I got it from a junkyard, I think i will just return it and try another on.
you cant put it on wrong right, i mean it only goes on one way.
thanks
