Ebrake problem
Old Dec 29, 2005 | 09:12 AM
revo's Avatar
revo
Default Ebrake problem
HI, I have a problem w/ my integra ebrake lite. When i start to run my car for the 1st and 2nd shift, the ebrake lite will turn on if i go over 2000rpm, on the 3rd shift, the lite will turn off by itself...i checked the master cylinder, brake fluide, brake pads and everything looks fine to me. Will that be just a problem of the O2 sensor??
Old Dec 29, 2005 | 09:17 AM
Brar's Avatar
Brar
O2 sensor? they have O2 sensor in a brake sys?
check ur brake lines for a pinch or anything.
Old Dec 29, 2005 | 09:34 AM
revo's Avatar
revo
I am not sure, because when I looked in other forums, they said that the O2 sensor goes bad and need to be replaced.
Old Dec 29, 2005 | 03:40 PM
Brar's Avatar
Brar
O2 sensor for wat? i dont think there is one for the brake sys...there is no O2 in a brake sys...thats y u bleed brakes...
anywho, just check all of the brake lines
Old Dec 30, 2005 | 12:18 AM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
The only thing that turns your ebrake light on and off is a small push button switch. Take out the center console and pull up on the ebrake. See that white button switch? Thats the switch. Its deactivated when you lower the ebrake handle all the way down and activated when you pull up on it.
I don't know why it would be going on and off like that.
Old Dec 30, 2005 | 07:31 AM
revo's Avatar
revo
Thanks alot for the information, i will try to look for the white switch today when i get home.
Old Dec 30, 2005 | 08:54 AM
bnuk's Avatar
bnuk
just try topping off the fluid. I know its probably above the min line, but mine did that for a while until I took it right up to the max. I think what happens is when you accelerate it sloshes back and the float drops down a little.
Old Dec 30, 2005 | 12:07 PM
revo's Avatar
revo
Is that the reason, because the brake fluid in my car just slightly above the min, and I think is still gonna be fine, so I didn't care about that. So do I just open the cap and pour the brake fluid in it?
Old Dec 30, 2005 | 02:48 PM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
yes...only proper (dot3) fluid....but yeah just open the resevoir, pour it in...pump your brake a couple times...with the cap closed...and do that until it's at or just below the "max" line
