SES after replacing distributor?
Old Dec 26, 2005 | 08:58 AM
montemann's Avatar
montemann
Default SES after replacing distributor?
I just got the integra running with a new distributor and it is faster than ever
but now the idle is kind of high and the check enging light is on, did i put the distributor on wrong or something, I put the 3 bolts on and the 2 harnesses anything else I could have missed
Thanks
Old Dec 26, 2005 | 11:15 AM
dohcvtec's Avatar
dohcvtec
so ur idle is high....all have to do is set ur distributor, rite now ur idle high rite because it set as advance rite now...so set it to the standard level...loose only 3 bolts
Old Dec 29, 2005 | 09:03 AM
montemann's Avatar
montemann
Hi
Im not sure I understand, I dont know how to "set" it exactly.
when i put it in, it can only go in one way, so how do i know if i advanced the timing or not
Would that set off the Check engine Light??
Old Jan 2, 2006 | 01:16 AM
waaBAAH's Avatar
waaBAAH
check your code....im not sure what car your workng with.(obd0 obd 1 obd 2) the dist. is moveable. set it somewhere in the middle. meaning loosen all three bolts and turn the dist all the way left and all the way right to get a feeling for the middle. (best way i can describe it to him sorry). ideally you would want a timing light. manual will explain more on this.
