96 coupe leaking! Fixed everything i can think of! please help
Old Dec 24, 2005 | 06:22 PM
Melt's Avatar
Melt
the lone outdoorsman
Default 96 coupe leaking! Fixed everything i can think of! please help
the water is coming in the bottom left corner of the trunk. My stock tails were cracked, so i put new ones in and put silicone on the gaskets before i put those back on the car. Still leaked, so then my friend who also has an integra helped me to clean the sunroof drain which wasnt really dirty, and we cut the hole bigger at the bottom so it wont clog up ... but i still have a minor leak SOMEWHERE and its still coming in at this corner of the trunk
Im SURE its not my window. My trunk seal looks good
Is there maybe a hairline crack along the sunroof drain pipe i cant see?
My friend and i are planning on taking the whole thing apart again, but i was wondering if anyone has any other ideas.
Old Dec 26, 2005 | 11:19 PM
Melt's Avatar
Melt
some pics
i siliconed under the power antenna too in case it was that
I had my friend sit in the trunk while i poured water everywhere .. we couldnt find the leak, but its supposed to rain tommorow.
So ... ive now taken everything apart the right way, and am not going to put anything back in till i find the leak.
The white stuff is coca ... er i mean baby powder.
I think it might be coming from this fuckin thing
this is from right behind the front door looking back ... im guessing this car was crashed and those are the holes from where they pulled out the dent
my poor car
Old Dec 26, 2005 | 11:23 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
You need to replace the taillight gaskets, not silicone them. Have you gotten inside the car and had someone with a hose pouring water on your car to see where exactly it is leaking?
Old Dec 26, 2005 | 11:33 PM
Melt's Avatar
Melt
yes my friend has gotten inside the car ... i poured water all over the tails when we checked and thats not where its coming from
i blasted the hell out that bitch with the silicone so they are sealed up HELLA good
its supposed to rain all day tommorow so we will see whats up with it
nice car by the way i checked out your car domain sometimes i wish i got white
Old Dec 27, 2005 | 06:27 AM
VPUPPY's Avatar
VPUPPY
That thing your referring to is a vent that is part of the air circultation of your car. It lets air out, but does not let air in. There should be a flap on it and it exits the car under the bumper cover.
Old Dec 27, 2005 | 02:36 PM
Melt's Avatar
Melt
ok so heres what ive found so far for today
its coming in ABOVE the taillight WTF
up and behind in there
then it trickles down the side, onto the top of the airvent lookin thing
and the water comes to rest down here
like i said its NOT the taillight leaking.
My friend went to arizona and i have to feed his cats so i decided ill make use of his garage since its raining hella hard here .... so i took my taillight back off and my silicone job was pretty good, but anyways, the water is coming in ABOVE it like i said earlier, cause all the baby powder up there is soaked ... its not coming through the taillight at all!
Can anyone reccomend a good sealent that i can just spray everywhere and maybe that will cure the leak, cause i still cant figure out where it would be coming from.
Old Dec 27, 2005 | 09:54 PM
Melt's Avatar
Melt
so i started a thread on hondatech and found out hella stuff from this other dude whos car is also leaking
http://honda-tech.com/zerothread?id=1474903
