Test pipe check engine light
Old Dec 14, 2005 | 06:54 AM
Iceberg157's Avatar
Iceberg157
HAHA
Default Test pipe check engine light
99 ls / I added a bolt-on test pipe to my setup this weekend cold air intake, headers catbakc exhaust cam gears, and clutch. The car is running good, and fast, but after a few hours driving the car with the test pipe, my check engine light came on. Since i got the car 1 year and a half ago, the light has never came on. I know it is from the O2 sensors because of the high flow fuel because the car is confused with no cat. But what is funny ever since the check engine light came on the car has been running crazy fast. Down low and even more up top. I lost nothing, but gained a lot. Mayve that is because I have an RSR ex mag. Someone told me i could get wideband o2 sensors to fix the check engine light possibly. Also I plan on adding an apex afc to tune the car. WHat do y ou guys think
Old Dec 14, 2005 | 12:27 PM
FooD2000's Avatar
FooD2000
Still Water
I'm not sure what your question is exactly... I'm guessing it's "how can i turn off the cel?" Well you've said it yourself, it's due to your 2nd o2 sensor (bank2) which lets the ecu know if your cat is doing it's job. Since there's no cat, Your Cel will always be on. Buy a highflow cat: No cel, legal, better for our enviroment and just as good.
Old Dec 14, 2005 | 01:48 PM
97civicEXVTEC's Avatar
97civicEXVTEC
i have a test pipe and never threw a code with it.. you probaly mess up one of the o2 sensors.. did you check to see what code it is?
Old Dec 14, 2005 | 04:05 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
• Ditch the test pipe.
• If your state will let you, run a high-flow cat instead, matched to your header diameter.
• Once an operational catalytic converter has been fitted and both O2 sensors are plugged in and operational, pull the + (positive terminal) battery connector and let the car sit for 10 minutes.
IMPORTANT: If you have an OEM radio installed, be sure you have the Anti-Theft code in hand BEFORE DISCONNECTING THE BATTERY.
• Once 10 minutes have elapsed, reconnect the battery and go for a drive.
If the Check Engine Light comes back on during your drive, retrieve the code using the directions in our FAQ thread. Then come back to us for assistance.
And ignore your friend's advice.
A wideband oxygen sensor would not fix the problem on it's own.
The OBD-II networks expect to see a drastic reduction in post-catalytic converter o^2 content. When both narrow-band sensors report the same level of o^2, the ECU figures that either a) the cat is not performing properly or b) it isn't there at all.
Old Dec 14, 2005 | 08:03 PM
jjang's Avatar
jjang
lovin the white font ha
Old Dec 14, 2005 | 08:54 PM
dubcac's Avatar
dubcac
I
Does your test pipe have a bung for the O2 sensor? If so, the reason the light is on, is that the O2 sensor is getting a reading that it's not supposed to get. A way around this, is to tie the sensor up under the body, and wrap it in tin foil...just expose it to atmospheric air.
Old Dec 15, 2005 | 02:33 PM
TheOtherDave™
Apathy Kills
h: Actually, that was entirely accidental. Sorry.
I've always used the black/grey scheme and I got sloppy in removing a highlight color for the bold underlined text. No wonder you guys couldn't read it. :uhhok: Oops.
Old Dec 28, 2005 | 01:03 PM
Iceberg157's Avatar
Iceberg157
HAHA
I never checked the code, but with the test pipe I got a good amount of power. I had a high-flow cat, but it started to make noise from inside. I was going to buy wideband o2 sensors, get an afc to tune the fuel and adjustable fuel regulator, and also there is a thing called the 02 simulator that tells the computer that the o2 sensors are ok. As for the envirnoment, it is not that serious when compared to tractors or any fucked up car spitting out smoke. My car does not even give off fumes or anything. Thanks for the posts guys.
Old Dec 29, 2005 | 12:49 PM
94civicEX's Avatar
94civicEX
I got worms.
Get an o2 sim.
99 Integra GSR
06 TSX
duck squad member #00003
Old Dec 29, 2005 | 06:03 PM
dubcac's Avatar
dubcac
I
Actually it does emit significantly more emissions than a car equipped with a cat.
