CTR Piston question
Old Dec 12, 2005 | 05:40 AM
mikey_e69's Avatar
mikey_e69
Default CTR Cams question
how much do they help on a mildly modified gsr??? and is this a DIY type of project? i just wunna know if its worth the money!!!
Old Dec 12, 2005 | 09:57 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
It will raise compression to around 12:1, so I wouldn't consider it unless you have some engine management available to tune the car. It may have issues running on pump gas too.
I wouldn't consider piston swaps as a DIY unless you really know what you are doing. It would probably take around 9-10 hours if, and only if, you knew what you were doing. Otherwise, it will be a complete nightmare. You would also have to rering it and hone it.
Old Dec 12, 2005 | 11:18 AM
mikey_e69's Avatar
mikey_e69
bump for the misprint. isaid pistons and i meant cams!!
Old Dec 12, 2005 | 11:44 AM
Provocateur
On permanent hiatus
In that case...I would highly recommend it.
I have a set in mine right now and they are pretty easy to put in if you know what you are doing and provide a good gain.
