Looks Like I'm Finally Gonna Boost...
yup. tonight 2gr84u suggested checking out www.homemadeturbo.com. there, i found a guy selling parts of a turbo kit. as i talked to him, i decided... it's mine
$430 shipped is going to get me the following...
"-manifold
-t3 turbo
-flanges
-lines, block fitting
-fmu
-missing link
-downpipe
-6psi wastegate
-2.25" steel pipe with 1st gen dsm bov (blue)"
i know it isn't complete. but two things hooked me... its cheap, and better than the turbo setup i DON'T already have. lol, so hopefully within the next couple months, i'll get it all put together and have it runnin. hoping with a few other mods to get near / past 200 hp. need to get some gauges, uberdata, some piping, clutch & peolly some other lil odds & ends.
$430 shipped is going to get me the following..."-manifold
-t3 turbo
-flanges
-fmu
-missing link
-downpipe
-6psi wastegate
You don't NEED a turbo timer, but it is nice. I really think you should look first at some better fuel management than an FMU and missing link.
If you don't yet have exhaust, you will want to look at something a bit larger too.
Your list looks good, but you will also need some larger injectors if you want to get serious with the fuel management.
ok, i figured instead of the turbo timer, i could juss let the car sit for a few minutes brfore i shtu it down. i've got all my exhaust replaced, except the stock pipes. i figured i might go a half inch bigger to relief the extra backpressure.
as far as the FMU and missing link.. .what would you suggest?
Originally Posted by delsol161
ok, i've got all my exhaust replaced, except the stock pipes. i figured i might go a half inch bigger to relief the extra backpressure.
then what do you have replaced? if the stock pipe isnt replaced? im confused please re-word that
sorry, i mean the cat, and axel back. from cat to axel bck, the stock pipes are there. i said it wrong.
450 injectors would be plenty right? 2gr84u said he has me covered on getting my ecu utaken car of
stuff you need or should highly consider:
450cc injectors
walbro fuel pump (190 is sufficient)
u need a fitting welded into your oil pan
intercooler
BOV
couplers
boost guage
ditch the missing link and FMU, pick up or chip your ecu for uberdata.
450cc injectors
intercooler
BOV
couplers
boost guage
450cc injectors
intercooler
BOV
couplers
boost guage
450cc injectors
intercooler
BOV
couplers
boost guage
i have an AEM fuel rail i got last year. is it worth putting on (w/ a FP regulator)? or wil lthe fuel pump be enough?
