sohc pistons
Old Nov 13, 2005 | 08:32 AM
dank24's Avatar
dank24
Default sohc pistons
What is a good piston for a d16z6 block. I am going N/A.
Old Nov 13, 2005 | 10:43 AM
1995Civic's Avatar
1995Civic
I hate ricers
CP or JE High compression. There are a few good ones, I just picked those two because of their good rep.
Old Nov 13, 2005 | 11:33 AM
Wharbone's Avatar
Wharbone
The z6 is a lame N/A motor. You will spend a ton of money to still have a slow car.
Old Nov 13, 2005 | 05:46 PM
1995Civic's Avatar
1995Civic
I hate ricers
I second that one.
Old Nov 14, 2005 | 06:40 AM
'98 EX RED's Avatar
'98 EX RED
King of the Auto Civic
Just answer his question...
Im doing the same thing on my y8, and JE were my choice pistons, coupled with Eagle Hbeam rods and a nice zex cam. The goal is nitrous eventually...
Old Nov 14, 2005 | 09:31 AM
3rdgenlxi's Avatar
3rdgenlxi
Really the only way to get fast on a N/A SOHC 1.6 is with a stroker kit and cams. Anything less would really get uncivilized. You NEED displacement for a N/A build - just revving it higher won't get you more torque. The usual way N/A makes horsepower is with high compression ratios.
Old Nov 14, 2005 | 11:41 AM
dank24's Avatar
dank24
Ah, I desided to swap it. It will never be as fast as a gsr swap even if i build it up.
Old Nov 14, 2005 | 12:37 PM
Wharbone's Avatar
Wharbone
Good to hear!
For as much as you would spend building a N/A d series, you would be disapointed with the final result.
Old Nov 15, 2005 | 05:08 AM
'98 EX RED's Avatar
'98 EX RED
*nitrous*
Old Nov 15, 2005 | 06:40 AM
Wharbone's Avatar
Wharbone
Originally Posted by '98 EX RED
*nitrous*
*Then it wouldn't be N/A*
