sohc pistons
Nov 13, 2005 | 08:32 AM
sohc pistons
What is a good piston for a d16z6 block. I am going N/A.
Nov 13, 2005 | 10:43 AM
CP or JE High compression. There are a few good ones, I just picked those two because of their good rep.
Nov 13, 2005 | 11:33 AM
The z6 is a lame N/A motor. You will spend a ton of money to still have a slow car.
Nov 13, 2005 | 05:46 PM
Quote:
I second that one.
Nov 14, 2005 | 06:40 AM
Just answer his question...
Im doing the same thing on my y8, and JE were my choice pistons, coupled with Eagle Hbeam rods and a nice zex cam. The goal is nitrous eventually...
Nov 14, 2005 | 09:31 AM
Really the only way to get fast on a N/A SOHC 1.6 is with a stroker kit and cams. Anything less would really get uncivilized. You NEED displacement for a N/A build - just revving it higher won't get you more torque. The usual way N/A makes horsepower is with high compression ratios.
Nov 14, 2005 | 11:41 AM
Ah, I desided to swap it. It will never be as fast as a gsr swap even if i build it up.
Nov 14, 2005 | 12:37 PM
Quote:
Good to hear!
For as much as you would spend building a N/A d series, you would be disapointed with the final result.
Nov 15, 2005 | 05:08 AM
Nov 15, 2005 | 06:40 AM
Quote:
Originally Posted by '98 EX RED
*nitrous*
*Then it wouldn't be N/A*
