NEed Help Fast, removing motor mount!!
Old Nov 6, 2005 | 02:10 PM
Schwa's Avatar
Schwa
Schiggity
Default NEed Help Fast, removing motor mount!!
Im swapping the timing belt and following the t-i.net instructions. Doesnt say anywehre that i have to support/brace the block. Do i need to do this, or will the other mounts support the weight??
Old Nov 6, 2005 | 02:55 PM
FooD2000's Avatar
FooD2000
Still Water
no you need to do this because when you take the motor mount off, the engine will only be supported by the right motor mount and tranny mount. Also your gonna need to raise the engine a bit putting the mount back on.
Just take a hydralic jack and use a block of wood and jack it under the oil pan before you pull the motor mount.
so wood inbetween jack / oil pan! Good Luck!
Old Nov 6, 2005 | 04:40 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
It probably isn't necessary to support the motor since the rear, tranny and passenger side front mount will be plenty to hold it in.
If you want to be safe about it, just do like FooD says.
Old Nov 7, 2005 | 12:08 AM
Schwa's Avatar
Schwa
Schiggity
Hey thanks. Turns out I didn't have to do shit to it. Worked out fine.
Old Nov 7, 2005 | 08:50 AM
FooD2000's Avatar
FooD2000
Still Water
Safe is safe but hey, glad it all worked out.
Old Nov 7, 2005 | 08:51 AM
Schwa's Avatar
Schwa
Schiggity
Yeah Thanks I appreciate the quick reply!
