H22 in '92-'95 Civic HB?
Old Nov 1, 2005 | 11:43 AM
PunkAssKidThe1s's Avatar
PunkAssKidThe1s
Team Babu
Default H22 in '92-'95 Civic HB?
I've seen some people do it. Is that any better than putting a b series motor in?
Thanks!
Old Nov 1, 2005 | 12:09 PM
3rdgenlxi's Avatar
3rdgenlxi
Yeah it can be done. Your acceleration will be killer.... until you try to turn a corner. have you ever driven a bike with someone hanging off the handle bars. it's the same effect when you put a heavier engine in the car. You mess up the balance...
Old Nov 1, 2005 | 12:19 PM
PunkAssKidThe1s
Team Babu
Hmm, how much extra weight approx. do you think that'd add w/ basic mods, and would taking things such as AC out, as well as swapping for carbon fiber help ease the majority of the weight up front to help maintain a decent balance?
Alright, and one more question... this guy says he has a D16Z6 engine in his '94 Civic HB (EX) and has the following: HKS super sequential blow off valve, 38mm external wastegate, turbo is an ar 50/70 with garret internals, it is a T3/T4 hybrid, T304 stainless header, short throw shifter, aftermarket headlights, carbon fiber hood, complete header back oex racing stainless exhaust, and puts out an estimated 300 hp? Would that be right or he is just claiming bigger numbers to try and impress?
Thanks!
Old Nov 1, 2005 | 12:59 PM
ewood87's Avatar
ewood87
Eric Wood
i doubt the guy is making 300 horse, and dont listen to the h22 haters. they are just uneducated. it weighs like 50 pounds more, just get some stiffer springs and lighten up the front a little and your fine. its a good motor w/ lots of torque and power. its a bit of a squeeze into the engine bay, but it fits fine.
also.. theres tons of topics on the h22 already.
Old Nov 1, 2005 | 01:07 PM
PunkAssKidThe1s
Team Babu
Alright thanks and thanks! Sounds good.
Old Nov 1, 2005 | 03:47 PM
junior-ae's Avatar
junior-ae
There was just a pretty long thread on the weight differences between the H22 and B-series. Look back a day or two. Essentially comes down to 35lbs-ish.
Old Nov 1, 2005 | 03:52 PM
junior-ae's Avatar
junior-ae
Matter of fact, here it is. There's a link to a Honda-tech forum where some guy actually weighed a couple different engines and presented the results.
https://www.honda-acura.net/forums/s...d.php?t=211147
More than the weight, it seems like the consensus is that the biggest factor in doing this swap is the complexity and making sure the car is balanced (weight wise). The suspension has to be set up properly afterwards.
Personally, if I had buckets of money, a ton of time, and a second car, I'd love to drop an H22 in my EX.
Old Nov 1, 2005 | 04:20 PM
PunkAssKidThe1s
Team Babu
Alright, sweet, that helps alot! Thanks!
