96 civic ex questions
Old Oct 31, 2005 | 05:19 PM
RSXt3's Avatar
RSXt3
Default 96 civic ex questions
first off when i bought my car the passenger side running/turn signal light worked but it quit and upon looking at it i discovered that two of the three wires were spliced and twisted together but they didnt have any electrical tape or anything on them. so i assume that they shorted and thats the problem but i cant find any blown fuses realys or anything. bulb is good.
please help.
next my keys were stolen by some hatin ass losers and it had my keyless remote.
if i buy one from the junkyard can it be programmed for my car?
next i have a y7 head and intake mani with only 40k on it and i was was wondering if the injectors are the same as the y8 so i could swap them since my y8 mani has 105k and it has a miss at idle, so i assume they are probably a little dirty
please help greatly appreciated.
Old Nov 1, 2005 | 01:57 PM
96GreenCivic's Avatar
96GreenCivic
Well as for the wiring, go back in there and clean it up. Solder and shrink tubing is your friend. You can find a transmitter off a junkyard I guess or ebay it. It should be programable.
Sorry, I'm not technically inclined, so I can't comment on the engine.
GL.
Old Nov 1, 2005 | 09:47 PM
bambbrose's Avatar
bambbrose
the injectors are the same. It would be nice to swap them but usually injectors aren't a problem when you have a slight miss. Check all other things before going through the hassle of changing out the injectors
