Help on changing oil pan!!!
Old Oct 31, 2005 | 11:09 AM
shangyer's Avatar
shangyer
Default Help on changing oil pan!!!
I screwed up my oil pan thread! I tried an oversized bolt but it still leaking. So Now I wanna change the whole pan. If anyone has instructions? I have a CHILTON book but it not so detailed. My car is 93 teg, 1.8L.
The Garage will chage me more than 400 bucks so please help me out here!
Old Oct 31, 2005 | 11:16 AM
94civicEX's Avatar
94civicEX
I got worms.
As far as I know.
Drain the oil.
Pull the pan.
Replace the oil pan gasket with a new Honda Oil Pan Gasket.
Replace with new pan, torque to spec.
Fill Oil, check for leaks.
99 Integra GSR
06 TSX
duck squad member #00003
Old Oct 31, 2005 | 11:18 AM
shangyer's Avatar
shangyer
there is exhaust pipe below the pan. Is it easy to take it off!
As far as I know.
Drain the oil.
Pull the pan.
Old Oct 31, 2005 | 11:24 AM
94civicEX's Avatar
94civicEX
I got worms.
Uh, yea.
Unbolt the b-pipe from your exhaust manifold and drop the hangers...
You might just want to have a shop do it for you if you can't figure that out yourself.
File Type: gif
99 Integra GSR
06 TSX
Old Oct 31, 2005 | 11:34 AM
shangyer's Avatar
shangyer
Any suggestions where to buy the pan and gasket, Do I have to buy OEM? I believe maybe I should replace the gasket too though it is not leaking from gasket! Right?
Old Oct 31, 2005 | 11:41 AM
94civicEX's Avatar
94civicEX
I got worms.
Replace the gasket with an OEM gasket.
I'd replace it all oem, but if you want to replace it with an OEM spec pan from a different manufacturer, go ahead.
99 Integra GSR
06 TSX
Old Oct 31, 2005 | 01:38 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
i'd get all oem parts also, its not that hard of a job to do. you should be fine :thumbup:
Old Oct 31, 2005 | 02:45 PM
shangyer's Avatar
shangyer
I decided to buy the OEM parts, the thing is I havn't found any leaking from gasket, Is it necessary to replace the gasket too when I change a new pan? Also, if I should replace all the bolts and nuts?
Thanks
Old Oct 31, 2005 | 02:49 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
you might as well change it since its off, i wouldn't reuse the gasket. the nuts and bolts can be reused. make sure you torque to spec though so you don't snap any of the bolts
Old Oct 31, 2005 | 02:51 PM
shangyer's Avatar
shangyer
Thanks! Oh well, The book says I might need some liquid gasket. What is that? Something like glue?
