Fuel pump install
Well, all parts are bought for the turbo setup, ok mabye like 1 more to go. BUT the fuel pump came in and id like to install it now. the weather is decent and i want to do it out side and not in my garage(fumes, high, spark, boom). anyways. can I do the fuel pump install now and still drive around for like 2 more weeks b4 i put the car away. Its the walbro 255LPH pump. so everything will be the same, BUT the new pump. i know where and how to do it. BUT will this hurt the motor in any way? Thanks guys
He won't have more pressure. The pressure is still controlled by the fuel pressure regulator...he'll be flowing more volume.
Originally Posted by rugsr
so ill be wastin gas? worse MPG? what about motor damage?
ah so all systems go then. its still the stock reguator right now. ill put the new one in very soon
You really don't need an adjustable one unless your injectors are too small and to compensate, you increase the fuel pressure.
i'd get a fuel pressure gauge. my friend just went turbo but before he put the turbo on he put his walbro 255 on and left his stock fpr and when he installed the guage it was reading that his fuel pressure was at 55psi instead of 40psi.
Then his FPR wasn't functioning properly.
