LS/Vtec ECU Q's
Quick question....I'm in the process of doing my ls/vtec swap and i needed the get the new ECU...is it just the OEM GSR ecu or would it be better to go with a virgin ECU and just have it programmed...both for money and later engine mods. Thanks
I'd go obd1 P72 as well. However, you will need to wire a knock sensor. If you have a b16 head, or a GSR head with skunk2/jg manifold, a DOHC converted P28 might be a better choice.
yeah thats what i was thinking....the OBDI P72....but...does anyone know a good source to get it from....im out of orange county so if it's close enuff then i'd go for it or possibly a high quality good deal internet source
whats the diff between the OBDI and OBDII p72's .... im not understanding why i'd wanna go with an OBDI when they make the same thing with the II
yeah i knew about the conversion if i went with OBDI....cool then...thanks guys...i'll keep ya posted...i got my buddy over @ skunk helping me out with the intake manifold/camshafts/gears/seals/valves/springs....so im saving a few hundred right there
You could do the P72, but you have to wire in a knock sensor, and if your doing a mild build on a ls/vtec then id simply go with a chipped p28 and slap a hondata s1, or s2 on... it will run really good... Also make sure to not use your Ls pump, i did and i didnt have any vtec, now i have a typeR... makes nice powa now!
