Honda-Acura.net (https://www.honda-acura.net/forums/index.php)
-   Integra & 97-01 Integra Type-R (https://www.honda-acura.net/forums/integra-and-97-01-integra-type-r-17/)
-   -   LS/Vtec ECU Q's (https://www.honda-acura.net/forums/integra-and-97-01-integra-type-r/210502-ls-vtec-ecu-qs.html)
tegbooster Oct 24, 2005 11:02 AM
LS/Vtec ECU Q's
Quick question....I'm in the process of doing my ls/vtec swap and i needed the get the new ECU...is it just the OEM GSR ecu or would it be better to go with a virgin ECU and just have it programmed...both for money and later engine mods. Thanks
Provocateur Oct 24, 2005 11:10 AM
You could get an OBD1 P72 that will work for your current setup and then allow you to chip it and have it tuned down the road if you need it.
dubcac Oct 24, 2005 04:53 PM
I'd go obd1 P72 as well. However, you will need to wire a knock sensor. If you have a b16 head, or a GSR head with skunk2/jg manifold, a DOHC converted P28 might be a better choice.
tegbooster Oct 24, 2005 05:05 PM
yeah thats what i was thinking....the OBDI P72....but...does anyone know a good source to get it from....im out of orange county so if it's close enuff then i'd go for it or possibly a high quality good deal internet source
Provocateur Oct 24, 2005 10:14 PM
I would search this forum and other honda forums to see if you can find a deal. They are rather expensive, but I have managed to buy two of them off the forums for around $160 shipped. Ebay prices will be a good amount more, so use that as your last resort.
tegbooster Oct 25, 2005 12:31 PM
whats the diff between the OBDI and OBDII p72's .... im not understanding why i'd wanna go with an OBDI when they make the same thing with the II
Provocateur Oct 25, 2005 02:10 PM
An OBD2 ecu is worthless because it cannot be chipped. If you just want the car to run in its stock form and don't plan on modding it further, you can just buy the OBD2 ecu.
94civicEX Oct 25, 2005 02:47 PM
So you'll also have to purchase a conversion harness.
tegbooster Oct 25, 2005 10:27 PM
yeah i knew about the conversion if i went with OBDI....cool then...thanks guys...i'll keep ya posted...i got my buddy over @ skunk helping me out with the intake manifold/camshafts/gears/seals/valves/springs....so im saving a few hundred right there
PoorMansR95 Oct 26, 2005 07:10 PM
You could do the P72, but you have to wire in a knock sensor, and if your doing a mild build on a ls/vtec then id simply go with a chipped p28 and slap a hondata s1, or s2 on... it will run really good... Also make sure to not use your Ls pump, i did and i didnt have any vtec, now i have a typeR... makes nice powa now!
© 2026 MH Sub I, LLC dba Internet Brands
