95 GSR intake manifold.
Old Oct 24, 2005 | 08:36 AM
psx_pat's Avatar
psx_pat
Default 95 GSR intake manifold.
I have B16A 1st generation engine. Is it possible if I change my intake manifold (the still have PGM-F1 printed) and throttle body to 1995 GSR intake manifold and throttle body? Is it direct fit? Also mine is 58mm TB and GSR have 60mm TB, does this make a big difference in throttle response. My modification so far is basic bolt on like i/e/h and I already change the block to B20B engine block. Thanks.
Old Oct 24, 2005 | 08:55 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
A GSR manifold will not bolt onto anything besides a GSR head. Even if it could, your better option would be a Type-R manifold because its runners are fatter and shorter and the plenum is much larger than the GSR manifold. It will also bolt right up, so you should look into that.
Old Oct 24, 2005 | 10:09 AM
teg92's Avatar
teg92
WHAT OK YEAH!
schmoo is right it wouldnt bolt up, try the type R one like he suggested or try buying a skunk2 intake manifold
Old Oct 24, 2005 | 06:59 PM
psx_pat's Avatar
psx_pat
Thanks. What you guys think about AEBS intake manifold,is it any good? And should I go 62mm or 64mm with my setting? Thanks.
Old Oct 24, 2005 | 10:22 PM
Provocateur
On permanent hiatus
I have heard great things about the AEBS manifold, so if you can afford it, it would be a good choice. I would go with the 62mm size unless you plan on some future forced induction.
Old Oct 25, 2005 | 08:59 AM
psx_pat's Avatar
psx_pat
No,probably not in the future to do force induction.At least not near future.
Old Oct 26, 2005 | 05:32 AM
psx_pat's Avatar
psx_pat
Does the 1995 GSR TB will direct fit to my B16A intake manifold?
Old Oct 26, 2005 | 05:59 AM
teg92's Avatar
teg92
WHAT OK YEAH!
ya it should bolt up
Old Oct 29, 2005 | 08:12 AM
psx_pat's Avatar
psx_pat
Does 2mm bigger TB will make a big differance in throttle response for my engine setup? Do I have to port match the intake manifold also? Thanks.
Old Oct 29, 2005 | 12:22 PM
Provocateur
On permanent hiatus
No, it won't make a noticable difference. Unless you just have the part lying around, I wouldn't even bother.
