Effects of high reving your engine?
Old Oct 17, 2005 | 10:14 PM
mxl36o's Avatar
mxl36o
1999 Accord 4 cyl
Default Effects of high reving your engine?
i used to have a civic, since i gotten my gsr, I tend to rev it ....alot. I hit vtec to 8k rpms several times, during short drives (i just like gunning it). Anyone else drives it hard? notice any ill effects? BTW it has 170k (i purchased at 158k). What are some signs of engine wear due to high rpms?
Old Oct 17, 2005 | 10:49 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Just make sure the oil is changed frequently and let the engine warm up before your full throttle runs to redline and it should be fine.
Old Oct 17, 2005 | 11:09 PM
FASTIMPORTS13's Avatar
FASTIMPORTS13
As long as your maintenece is up to date and you don't see an unusual consuption of oil, and also do like schmoo said you'll be k
Old Oct 18, 2005 | 05:09 AM
SP00NFed's Avatar
SP00NFed
FuK JDM
yup...what they said. My GSR has almost 170,000 miles too and it runs pretty good. I'm on my way to the dyno today to fix my a/f ratio.
Old Oct 18, 2005 | 06:13 AM
killuminati's Avatar
killuminati
All through your body
It's about time, if I recall correctly there were a couple of people who told you to get that Apexi controller a while back at one of the honda-tech meets.
As far as this thread goes, the GSR motor was designed for high revs, so have fun with it.
Old Oct 18, 2005 | 07:54 AM
SP00NFed's Avatar
SP00NFed
FuK JDM
i was patient though and got a vafc II for free from a good friend. If you wait good things will come to you
Old Oct 20, 2005 | 02:47 PM
95ac.teg's Avatar
95ac.teg
on my 92 ls. i would drive pretty crazy. i noticed that after a weekend of gunning it my idle was fucked up bouncing from 1,000 to 2000 and other rpm problems
Old Oct 20, 2005 | 06:25 PM
redGSRguy's Avatar
redGSRguy
You might burn more oil and your wallet will take a hit if you gun it everywhere =P. I'm pretty sure everyone drives their car hard every once in a while.
Old Oct 21, 2005 | 07:08 PM
Driverman5777's Avatar
Driverman5777
I have a 2001 ls and redline it at least 4 or 5 times a day and havent seen any problems yet but should i expect any.
Old Oct 22, 2005 | 11:14 AM
sirg-vtec's Avatar
sirg-vtec
I just wanted to fit in.
Yup. Now go redline your car. DOO EEET!
