Help!
I did B20VTEC conversion exactly like it says in http://www.c-speedracing.com/howto/b20vtec
But when I drove the car from 1st-3rd gear all shift at 7000 rmps but the VTEC won't kick in. After few times I tried then the check engine light shows up (code 22: oil pressure switch). Also does it matter the size off the hose I use? Cause before I use a slightly bigger hose,the VTEC won't kick in then I use exactly the same as it says on C-speed,still doesn't work.Both of them shows up code 22. Also I checked my oil pressure switch and it's working fine. Anyone knows what is the problem? Thanks.
