fuel filter in the tank. '02 accord
Old Sep 25, 2005 | 02:18 PM
thefullbug's Avatar
thefullbug
Default fuel filter in the tank. '02 accord
I was told the fuel filter is part of the fuel pump assembly and is inside the fuel tank .
I was just wondering when the filter stops up if you have to get the whole pump assembly.
Has anyone run into this yet.
Old Sep 26, 2005 | 05:55 PM
Accord2005NJ's Avatar
Accord2005NJ
I just recently spoke to Honda about this and yes. you need the fuel pump w filter (same unit)
Old Sep 26, 2005 | 05:58 PM
MrChad's Avatar
MrChad
THE RED 6th GEN Coupe
You shouldn't need a new filter or pump on an '02 Accord.
Old Sep 26, 2005 | 06:01 PM
Accord2005NJ
Yes, Mr. Chad is correct. You should not need it though...
Old Sep 27, 2005 | 05:10 AM
hoyoung02's Avatar
hoyoung02
HEAT:Shift_TechkaV
i thought the fuel filter was right before the fuel injectors?
Old Sep 27, 2005 | 06:13 AM
thefullbug's Avatar
thefullbug
Well what have they done to keep the filter from stopping up.
A filter is filter and will eventually stop up.
Old Sep 27, 2005 | 07:33 PM
scanrps's Avatar
scanrps
Honda Parts Tech
You can buy the filter separate from the pump, but you still
have to drop the tank to get to it. Like all Honda's 94 and newer, the
filter is consider "lifetime" and shouldn't require attention unless contamination
or you use ARCO gas.
