will gsr cam shafts work for my b18c5?
Old Sep 20, 2005 | 11:22 AM
hx5hift's Avatar
hx5hift
Default will gsr cam shafts work for my b18c5?
i recently had the head rebuilt and now all the shop needs are cams. will a cam from a b18c work for a b18c5?
i understand that there will be a loss in performance or whatever because its a downgraded cam shaft but will it fit? will the engine still work? will it be reliable if i dont rape the engine?help!
Old Sep 20, 2005 | 11:46 AM
b16ahybrid's Avatar
b16ahybrid
Yep, they will work.
If you look around you could probably find some ctr cams.
Old Sep 20, 2005 | 06:41 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
They'll bolt in just fine. It will be a slight performance hit, but if it gets the car running temporarily while you scope out some more aggressive ones, they will work just fine.
