Check engine light -- 75K
Old Sep 12, 2005 | 06:50 PM
fsugirl24's Avatar
fsugirl24
Default Check engine light -- 75K
Just after I hit 75K on my 99 honda accord coupe, my check engine light came on.
Any idea if it is programmed to do this? Or should I take it in and get it tested?
Old Sep 12, 2005 | 07:27 PM
MrChad's Avatar
MrChad
THE RED 6th GEN Coupe
My sister had the light come on around 80k mi, it may be related to the faulty EGR valves in some V6 hondas. Do you live in a snowy area?, winter blend gas is blamed for the fault in the valves. 8 of 10 times Honda will cover the cost of the repair under good faith. It requires the retrofit of a new egr valve, see your dealer or at worst see Autozone to get the codes....maybe you just left the gas cap on loose.
Old Sep 13, 2005 | 03:05 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
https://www.honda-acura.net/forums/s...d.php?t=202138
Old Sep 13, 2005 | 08:35 PM
lk21joker's Avatar
lk21joker
AnotherAccordOwner
I bought my car at 60k, it ran beautifully. Then when it reached 65k, check engine light turns on. What I did was to borrow the code reader from Autozones, found out that my sensor at the catalyst or the catalyst was bad ( i forgot which).
I did some research and found out that the car is still under warranty. I am the second owner, and I called the 1st owner for permission if I could use his name for the service, he said ok. I took it to the Honda Dealer and said I'm the first owner's brother. They check his name and the VIN, and guess what, they replaced the cat for free.
If your car is still under 70k or 80k, you might still have warranty for the emission system
