vigor egine installation HUGE problem? HELP
Old Aug 25, 2005 | 12:16 PM
virgil73542's Avatar
virgil73542
Default vigor egine installation HUGE problem? HELP
Here are some pics of what problem I ran into. the new engine (JDM) has four wires running from the head into the harness and no sensor when I opened the cover to the timing belt. The US version has six running into the harness and there is a sensor <--? under the timing cover. What I was thinking is get the sensor from the US put it on the JDM and merge the harness with the new wires and the old. What do you all think.
Help is appreciated.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Aug 25, 2005 | 01:05 PM
virgil73542
IIIIIIIIIIII know what that is now ... cranksensor... I guess I would need to merge them together... :thinking: :doh:
Old Aug 25, 2005 | 01:52 PM
virgil73542
i still don't know what to do thou
Old Aug 25, 2005 | 04:50 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
are you actually doing this without a service manual? :eh:
Old Aug 25, 2005 | 07:08 PM
Vigor's Avatar
Vigor
Shouldn't need to merge any wires. If you pull off the camshaft pulley, you'll see the sensor on the JDM motor/the other "half" of the sensor on the USDM. Just swap what's on the USDM motor onto the JDM, it's a direct fit IIRC. The key here is removing that camshaft pulley.
BTW...it's the Camshaft Position/Top Dead Center sensor.
Old Aug 28, 2005 | 06:44 PM
virgil73542
got it
take the sensors from the US version including the shaft wheel and move them to the JDM version. Simple
No, I am not doing this without a manual but the Chilton's don't go in detail.
After this point is really simple, every other transfer from the US version to the JDM was done.
Old Aug 28, 2005 | 06:45 PM
virgil73542
by the way. there are 2 more sensors behind the wheel and they need to be transfered too.
