GSR and oil??? [B18C1 in 96-00 Civic]
Old Aug 16, 2005 | 03:09 PM
dawrenn's Avatar
dawrenn
Default GSR and oil???
I recently got a 99 GSR engine swapped in my 99 civic. Yesterday is the first day I checked the oil level since I got the swap done. It was right at the first dot/hole on the dipstick. Is losing oil like that normal for a B18C1? I take it to VTEC everytime I switch gears and probably take it to redline 10 or less times a day. There is no smoke whatsoever even when I take it to redline. The engine has 67,000 miles on it. I looked at everything externally that I could and did not see any oil leaks, I have no CEL's and the car is still strong. What could it be?
Old Aug 16, 2005 | 03:20 PM
VTEC-Power's Avatar
VTEC-Power
have you got a oil change since the swap? you are supposed to 200 miles right after it, try using thicker oil also, I use 10w30 Mobil 1 synthetic
Old Aug 16, 2005 | 03:32 PM
dawrenn's Avatar
dawrenn
No, when I got the engine there was no oil in it so the shop put oil it. So I dont think I needed to do an oil change after 200 miles. I am using 10w30 Mobil 5000.
Old Aug 16, 2005 | 04:09 PM
boriblanco's Avatar
boriblanco
i dont kno why you are having that problem but just make sure you keep an eye on it because if the oil gets 2 low the v-tec wont engage
Old Aug 16, 2005 | 04:11 PM
dawrenn's Avatar
dawrenn
Originally Posted by boriblanco
i dont know why you are having that problem but just make sure you keep an eye on it because if the oil gets 2 low the v-tec wont engage
Other people with GSR's have told me they have had the same problem. I just wanted peoples opinions on here.
Old Aug 16, 2005 | 04:14 PM
dubcac's Avatar
dubcac
I
VTEC burns oil. It goes to a higher pressure and temp in VTEC...so if you're in VTEC a lot, that's where your oil goes.
Old Aug 16, 2005 | 04:21 PM
dawrenn's Avatar
dawrenn
I am glad you said that. I was getting hella worried. I really shouldnt be since I saw no oil leaks or smoke whatsoever. I am going to change my ways and start shifting gears around 4k rpm's and only go in VTEC sometimes or when I am racing.
Old Aug 16, 2005 | 06:00 PM
B18C Turbo's Avatar
B18C Turbo
no car no matter what should burn any amount of oil, its not good obviously. Do you see any smoke come out from behind you when you get on it?
Old Aug 16, 2005 | 06:06 PM
dawrenn's Avatar
dawrenn
I see no smoke at all even when I take it to redline.
Old Aug 16, 2005 | 06:09 PM
Brar's Avatar
Brar
mayb when u did the swap u didnt top off the oil?
