98 3.0 CL - Need help removing front struts
Old Aug 16, 2005 | 04:20 AM
ytse27's Avatar
ytse27
Default 98 3.0 CL - Need help removing front struts
Hi - Great site!
I have a 98 3.0 CL. How do I properly replace the front struts? I tried to compress the spring and remove them last night but it wasn't nearly enough and I suspect that I may have to remove the upper suspension arm to lower the assembly and remove the old unit.
Also, is there a specfic spring compressor that I should be using? Mine just barely fit in there.
Thanks everyone,
Mike
Old Aug 29, 2005 | 08:24 AM
SwervinCL's Avatar
SwervinCL
Reppin Tha 1st Gen CL
Did you get the strut out from your car?
