lowering
Old Aug 7, 2005 | 01:49 PM
Redblurr's Avatar
Redblurr
Pił Allentato
Default lowering
I heard that instead of buying new springs to lower a car, its ok to just cut the springs. Is that true. if possible how much should be cutoff? what r the pros and cons?
Old Aug 7, 2005 | 06:41 PM
you should never cut old springs. the springs are designed with the right number of coils for handling reasons. when you cut the springs you alter how they perform on the car. i know a couple shops in my area wont even do alignments on vehicles with cut springs.
Old Aug 7, 2005 | 07:12 PM
Redblurr's Avatar
Redblurr
Pił Allentato
Alright thanks for your imput dude. Good Looking out.
Old Aug 7, 2005 | 07:13 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Cutting springs is one of the worst ideas out there. Cutting aftermarket springs is even worse. It will kill your struts faster than you can imagine, as well as make your car unpredictable and unsafe.
With a set of name brand lowering springs like Neuspeed running around $125, just shell out the money. It will be much safer and will handle much better.
Old Aug 7, 2005 | 07:17 PM
Redblurr's Avatar
Redblurr
Pił Allentato
good looking out shmoo. i was just curious about the whole cutting the springs. i will buy some new lowering spring and shocks.
Old Aug 7, 2005 | 07:19 PM
Provocateur
On permanent hiatus
Great idea. Don't forget camber kits if you intend on a drastic drop. Anything much over 1.5" will usually require camber kits.
Old Aug 7, 2005 | 07:34 PM
Redblurr's Avatar
Redblurr
Pił Allentato
Can you explain what the camber kits do to the tire? i was just checking out the springs and shocks for a 91 teg and the whole setup is like 800+ dollars. not counting the camber kit. you said $125, where did you see that?
Old Aug 7, 2005 | 08:14 PM
Provocateur
On permanent hiatus
The camber kit just corrects the negative camber that results from lowering a car. You know when you see the bottom of the wheel facing farther out than the top, so it is pointed inwards? That is negative camber. It will wear your tires out on the insides if it isn't corrected.
I do all my shopping on ebay since it is very cheap.
Here are the struts I am running. They are cheap and get the job done better than the OEM shocks. http://cgi.ebay.com/ebaymotors/KYB-G...spagenameZWDVW
The springs are just a personal preference. I prefer Neuspeed, but you may want to go with Eibach, H&R, etc. Just find the proper drop height you want. Here is a set of H&R for $150 w/ free shipping. http://cgi.ebay.com/ebaymotors/H-R-S...spagenameZWDVW
And then here is a rear camber kit from Ingalls for $110. http://cgi.ebay.com/ebaymotors/CIVIC...spagenameZWDVW
It is a pricey endevour to do it right, but it will be worth it.
Old Aug 8, 2005 | 05:08 PM
Redblurr's Avatar
Redblurr
Pił Allentato
Nice setup. Thanks for your help shmoo.
