HELP! Clifford Alarm with Built-In Door Lock Relay
Old Jul 14, 2005 | 09:47 AM
Lex2Go's Avatar
Lex2Go
Default HELP! Clifford Alarm with Built-In Door Lock Relay
Guys I need some help: This is for a 1989 CRX Si
I have a Clifford Matrix 10 with built-in relay for door locks. There are 6 wires that's coming out of the haress and I can't see to get it to lock or unlock. This is for a 2 wires actuator. Can someone let me know what I'm doing wrong. I totally appreciate any help. Even better if you come by to just hook up the wire, everything is done except wiring to the alarm itself, I'll buy dinner. I'm located in San Francisco.
Thanks in advance.
Here is the Relay Harness Wiring Diagram:
Black/White DomeLight Supervision Relay Input #87
White/Black Lock #87a Normally Closed
Green/Black Lock #30 Common (Output)
Brown/Black Unlock #87a Normally Closed
Blue/Black Unlock #30 Common (Output)
Violet 12 volt
