How would you do both sides at the same time??? You have to remove the calipers and then remove both brakepads. Its farely easy hardest part would probally be compressing the piston on the caliper.
The first time i did it i was expecting it to be hard, but it only took me about 20 minutes in total, i didn't rotate the rotors though, that is recommended when changing pads.
