first time front breaks pads replacement...
Old Jul 10, 2005 | 04:50 AM
iamoverit2's Avatar
iamoverit2
Default first time front breaks pads replacement...
Hi. I confused: do I need to work at one wheel at the time? And do I have to remove pad retainers? Please,help!
Old Jul 10, 2005 | 06:18 AM
teg92's Avatar
teg92
WHAT OK YEAH!
How would you do both sides at the same time??? You have to remove the calipers and then remove both brakepads. Its farely easy hardest part would probally be compressing the piston on the caliper.
Old Jul 10, 2005 | 12:05 PM
MPerson's Avatar
MPerson
The first time i did it i was expecting it to be hard, but it only took me about 20 minutes in total, i didn't rotate the rotors though, that is recommended when changing pads.
