90 civic dx won't start ecu code 16
Old Jul 6, 2005 | 12:33 PM
ksull1016's Avatar
ksull1016
Default 90 civic dx won't start ecu code 16
I have a 90 civic dx, won't start when hot outside. ECU blinks 16 times when key is in the on position without cranking the engine. I've heard this indicates a problem with the fuel injection and that the main relay might be the culprit. Where is this located and how do tyou replace it?
Old Jul 6, 2005 | 06:10 PM
foot's Avatar
foot
By the drivers feet. Should be a little grey box. They are about 65 bucks.
Old Jul 8, 2005 | 08:07 AM
ksull1016's Avatar
ksull1016
thanks, I found a rectangular black box bolted with one bolt above and to the right of the brake pedal with a small wire harness connected to it. Could this be it?
Old Jul 8, 2005 | 06:04 PM
raiden571's Avatar
raiden571
turning u inside out
take a pic. go to a junkyard and get a couple for cheap
