F/S 00 Boosted ITR
Old Jul 1, 2005 | 12:54 PM
2005300C's Avatar
2005300C
Default F/S 00 Boosted ITR
Whats up everyone im NEW to this forum.
I have a 00 ITR yellow for sale im asking $25,000 obo (no lowballs)
2000 Acura Integra Type R, completely built turbo car. Engine has approx 500 miles since complete rebuild. Willing to work out a trade deal, clean title is in hand. Car has never been in an accident of any kind and is in mint condition. Below is a list of mods that are currently on the car, current setup is capable of 500 whp by slightly increasing the boost. I am looking to do a K swap in a hatch that is the reason im selling this car. If you are intrested you can email me at mohamad.ganchi@cingualr.com
Dyno Sheet from AMS, tuned to 410 whp at 18lb of boost
Specs
Jun Cam Gears, dual valve springs
Type R cams
New stock type R valves
Golden Eagle sleeved block, bored to 83mm, balanced and blueprinted bottom end 1.9L. Copper o-ringed combustion chambers
Arias Pistons, 9.5:1 compression ratio
Eagle connecting rods
Exedy 3 puck clutch and 8 lb flywheel
AEM ecu with wideband O2 sensor and 3bar GM map sensor, tuned by AMS of Chicago
Precision 780 CC/min fuel injectors
Custom goodridge braided oil feed and return lines for turbo
Moroso Oil Pan
Endyn Breather Kit
MSD ignition and blaster coil
Cometic Head gasket, .010" thicker than stock
South Florida Performance Tubular Turbo Manifold
HKS wastegate, set to 14lbs of boost
Thermal 3" exhaust
Apexi Full bodied coilovers
Greddy Profec B boost controller and turbo timer
Greddy Type S blow off valve
JDM "Honda" red valve cover
Autometer oil pressure, water temp, boost, and fuel pressure gages
AEM wideband O2 sensor gage
AEM fuel pressure regulator and fuel filter
Spoon Thermostat (colder openning temp)
C & R full length radiator with a SPAL slim fan
Precision T3/T4 turbo with 70AR and 60 series trim
Greddy front mount intercooler
Golden eagle fuel rail and oil distribution block
JDM OEM type R front end conversion
C West front lip
Recaro SRD seats with red stiching
Skunk 2 rear upper strut bar
Project U brake pads and slotted/drilled rotors (Front only)
Goodridge braided brake line
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Jul 1, 2005 | 05:38 PM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
nice car man
sorry to hear you'll be parting with her
g'luck with the sale
Old Jul 4, 2005 | 10:05 AM
2005300C's Avatar
2005300C
still up for sale
Old Jul 5, 2005 | 07:23 PM
Nelson's Avatar
Nelson
Administrator
Please Note the State of Where Vehicle is Being Sold in the TITLE
Effective 11/29/04
Please, as courtesy to potential buyers, note the state or providence of where the vehicle is located in the SUBJECT of the thread.
Example:
FS: 1998 Acura Integra; SoCal
Effective immediately, any thread created after this thread, that does not comply to this rule, will be closed.
-HAN Management.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
