JDM H22 or Jdm B16 sir
Originally Posted by rampage918
alright, Im planning on starting a project with a honda civic coupe. Which motor swap seems that it would be the best and run the hardest?
Providing your goals and budget is just the beginning..
Anyway... I have about $4k to spend right off the back. Im not sure if I should go turbo b16 or turbo h22, or if anyone has any good suggestions on all motor!
which one do you think is a better choice, the b16 turbo or h22 turbo. And also whave people heard about the F20b (accord trpe-r) in a civic coupe?
What exactly are you after?
What are your goals? Your not going to get much help being vague and asking "which is better" questions if nobody knows what your looking for.
You need to give information of what you want!! Do you want it to handle well? or is it just a drag car? how much power do you want? do you want it as a reliable driver? ETC...ETC.. A civic with a h22 will not handle very well!! too much weight in the engine, my freinds is a nightmare, even with coilovers it only helps aliitle bit!! If you want a fast civic which will handle well you shud stick to a b16 or b18, b18's are great, it just depend if you wanna go turbo/supercharged or N/A.if you do go b18 a teg engine will come with a LSD, a b18c4 (1800cc civic vtec) comes with a LSD after 98. no point in havin power if u cant put it on the black top! think about all these types of Q's and what you want, Then ask ppl to help
