91 accord -removed and reinstalled Balance Shaft Belt - won't start
Old Jun 24, 2005 | 08:36 AM
Randy Dick's Avatar
Randy Dick
Default 91 accord -removed and reinstalled Balance Shaft Belt - won't start
I was going to replace timing belt and Balance shaft belt - After opening up the covers to remove belts, it was determined that belts were already replaced by my brother (previous owner) and did not require replacement - We did take off the balance shaft belt to inspect - Engine was at TDC and first lined up timing marks on the pulley on the left looking at the engine, we did not align the key way on the center pulley located on crankshaft and could not find any timimg marks on the right pulley - It wasn't until we started to install the crank pulley that the key ways were not lined up - rotated crank until the key ways aligned and intalled key and crank pulley - ENGINE DOESN'T EVEN FIRE NOW - Will Not START
