good bad and broken
Old May 29, 2005 | 01:14 PM
FATHONDA's Avatar
FATHONDA
Default good bad and broken
i am considering this vtec swap someone calls a mini-me. I have quite the mods done and adding at time of swap here is my list, tell me what you think.
ported.10 polished vtec head, stage 3 cam cut, aem sprocket, dual carb intake modded to dual TBI, +30 pistions polished w/gapless top rings, polished rods, crank HP crank berrings (couldnt find hp rods ), 4.2.1 header. still pushin the mt 4 speed, shift point 4k normal cycle, dual coil with MSD Dist cap and external coils linked series.
does that sound like disaster or fun?
Old May 29, 2005 | 06:00 PM
turboB16's Avatar
turboB16
who cares if it blows its a minime theres thousands of them out there and u can pick em up for cheap......
Old May 29, 2005 | 06:02 PM
B00STisBetter's Avatar
B00STisBetter
get high comp pistons block guard and spray.
Old May 29, 2005 | 06:03 PM
B00STisBetter
the good things about d series is that a d16y8 complete is about 800 bucks.
Old May 29, 2005 | 07:46 PM
civicandtegra's Avatar
civicandtegra
god i cant find a gsr, trype-r head for under 6 complete
Old May 30, 2005 | 08:20 AM
pomansouth's Avatar
pomansouth
whats wrong with a b16 head, the type r and b16 have the same exact cast...
it sound like you have a good bit of stuff i have never heard of and if it works, kewl but i cant promise anything.
Old May 30, 2005 | 01:38 PM
FATHONDA's Avatar
FATHONDA
well, it sounds like even if it blows it will be fun till it does thanks guys and gals.
Old May 30, 2005 | 01:40 PM
FATHONDA's Avatar
FATHONDA
Default ok
is it that serious? should I sleeve my cylinders too?
Old May 30, 2005 | 01:47 PM
b16ahybrid's Avatar
b16ahybrid
no not for a mild build like that. Stock sleeves are good for over 300whp
