new transmission?
Old May 24, 2005 | 10:37 PM
typeSHpapi's Avatar
typeSHpapi
Default new transmission?
does any know how much it'll run me(more or less) to get a new tranny in plus labor... mines is pi***ng me off ... i can't shift at high rpms and because of that i'm finding myself constantly grinding gears....alot! all my gears must be f****** up...... the car is 97 type SH... thanks
Old May 24, 2005 | 10:46 PM
abexh22's Avatar
abexh22
rebuild tranny cost around $1000 you should install your own tranny its not that hard it takes 1 or 2 days
Old May 25, 2005 | 03:56 AM
5hift's Avatar
5hift
Hades: 2.2L DOHC VTEC
Try replacing the sycnromesh before you put up all that money for a new trany.
Old May 25, 2005 | 01:16 PM
mtbprelude's Avatar
mtbprelude
RIGHT Wheel Drive!!!!
I think what 5hift is trying to say is try replacing your transmission oil WITH synchromesh, or redline or Royal Purple. There are alot of high quality gear oils out there....look into them, and check your tranny oil level!
Old May 25, 2005 | 01:48 PM
5hift's Avatar
5hift
Yah, I was in class when I wrote that, so I had to rush it. :thumbup:
Old May 25, 2005 | 07:55 PM
typeSHpapi's Avatar
typeSHpapi
ok... this is a dumb ass question... but, how do i drain the transmission fluid and where do i pour new fluid into the transmission.. reason i ask is because i was looking at the owners manual and at the engine bay, and the only fluid "holes" i see are the brake fluid,egine oil, coolant fluid, power steering fluid, washer fluid, and clutch fluid "holes".... unless the transmission fluid is the same as the clutch fluid, i don't know where to drain it and where to pour it..... i see something about a filler bolt. but i don't know where it is or how to get to it. any help guys!!
Old May 26, 2005 | 05:21 AM
shivers's Avatar
shivers
Moderator Alumni
What year is your car? Is it a 5th gen Lude? If so, you may be covered by a warranty extension from Honda. The shift forks in these cars had a tendency to bend causing grinds at high rpms. A friend of mine went through 3 transmissions before selling his car. Shortly after it was sold, Honda extended the warranty of the transmissions. Check into it before you start swapping fluid.
2005 s2000
Old May 27, 2005 | 07:04 PM
typeSHpapi's Avatar
typeSHpapi
thanks for your input guys... if you guys have any more info for me, i'd love to hear it. any little thing you might know about this problem would really help me out alot as to desiding how to go about fixing it.. thanks again
hamlet
